Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Voyager & Town & Country
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 01-08-2012, 12:25 PM
Default No turn over for me !!!
Hi everyone, have enjoyd reviewing this site,lots of information thought I would be one of the lucky ones and miss out on some of the misfourtunes others have had,but not so. 2001 T/C 3.3 (black key) Current mileage is 51059, replaced PCM after dealership diagnostic indicated a PCM failure after vechile started running erratically. I replaced unit from Automotive Computer Exchange, vehicle ran like new, after two months while driving engine light came on with audio warning, all gages went to zero and engine quit. When attempting to start there is nothing, no engine turnover, there is an audible click from fuse box. Fuel gage shows empty which it isn’t, also unable to retrieve trouble code using the key dance (on off on off) or Craftsman CanOBD2 Diagnostic Tool (no codes found). Checked fuses and relays, jumped starter, turns over, did the dash smash, no luck, wiring harness appears fine, PCM was returned to ACE and they reported that unit function’s properly. . Any and all suggestions welcomed.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 01-08-2012, 05:58 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
need a better codes reader first of all if U have one of the cheap ones it will only read federal emission codes only.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 01-08-2012, 07:18 PM
Yea... thanks for the quick response..... what can I say ya deal with what you have, I also noticed that the fuel pump does not energize when key turned. Does the PCM prevent engine from turning over if pump is bad.
Old 01-08-2012, 08:13 PM
Are there any cheap scanners you would recommend for future use, mine should be able to pull DTC's to use as a starting point, but as I stated the key dance also resulted in no codes,where should I look first.
Old 01-08-2012, 10:51 PM
check for spark and fuel see which u are missing
__________________
KKeller608@aol.com
Old 01-09-2012, 01:00 AM
An audible click from the starter relay in the IPM means the control side of the relay (PCM ground to relay coil) is working. Confirm the starter relay is clicking. Where did you jump the starter? At the starter? At the relay? Jumper cables at the battery?
Early 4th generation vans have a known problem with corrosion in the IPM that can effect anything electrical on the van. Disconnect the battery then disconnect the IPM connections on the bottom. Inspect for corrosion. Might try a shake test on the connections and harnesses first.
Old 01-09-2012, 07:01 AM
It was jumped at starter,will go give it a shake and check fo corrosion
Old 01-09-2012, 12:31 PM
just curious,why no codes?
Old 01-09-2012, 12:46 PM
I answered this already
__________________
KKeller608@aol.com
Old 01-09-2012, 01:31 PM
Yes you did, scanner not big enough,sorry bout that, after I check for corrosion in IPM, how would you check for spark or fuel if nothing happens when ignition is turned on.
Tags
control, engine, pcm, turn
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
