Sponsored by:
Sponsored by:
P0401
Old 03-20-2014, 02:46 PM
jsiceloffj's Avatar
Smile P0401
I am getting a P0401 code on my 1998 T&C. I know the description indicates the EGR value, but does this code indicate a problem with the transmission? The code returns about 100 miles after being reset. The transmission seems to jump/slip when the code appears. I have changed the EGR as well as the mass air and several hoses. It was recommended that I clean the intake manifold. I'm ready to to clean the throttle body and check for vacuum leaks but I just wondered if anyone has had any transmission problems. I also saw someone had the EGR value reversed. I will check for that. The engine runs very good and am getting 21 MPG on the highway. Any help would be greatly appreciated.
Old 03-20-2014, 04:24 PM
no EGR and trans will be separate issues
Old 03-20-2014, 06:47 PM
jsiceloffj's Avatar
Smile
Thanks Kevin. I thought that to be true. Would reversing the EGR mounting result in this 401?
Old 03-21-2014, 12:56 AM
no 401 is an electrical issue inside the egr
Old 03-30-2014, 07:17 PM
D. Bacon's Avatar
I recently fixed the P0401 with a new EGR assembly, pretty easy to replace, but I hasd to soak a few bolts with liquid wrench.
2002 Voyager, base model 2.4L
hambone
01-13-2011 08:59 PM
sschwencer
05-10-2008 11:37 PM
smackdab
02-18-2008 12:49 PM
mazinger4
08-25-2007 12:47 PM
Quick Reply: P0401
