Part fell of from A/C compressor 2005 2.8CRD
they do do a repair kit but you need to look at see if the compressor is damaged, the splines, the bolt hole and make sure the compressor is not seized. I would recommend you look at replacing the complete unit.
My friend has an identical car, so we took this from his car and everything is working ok. I found it on german ebay: http://cgi.ebay.de/Klimakompressor-S...item439ea25211
They said that they can send me one for my car for 50€. Case closed
Make sure you check for oil around the outside of the shaft seal. If you see excess oil, you are losing refrigerant. You can buy a repair kit for that too, but specialty tools are required. Might as well replace the whole compressor then.
bradneal
08-22-2008 07:34 AM
