Pcm/ecm
Pcm/ecm
My 2001 T & C needed new PMC (also known as ECM) and my dealer quoted 1,016.00! Searched around and found AllComputerResources.com and can get same quality product for 275.00 shipped from them! It's guaranteed with $ back and all you do is disconnect negative from battery, disconnect two plugs from ECM, unscrew 3 bolts (one behind left headlight), bolt in new one, reconnect plugs, connect negative from battery! TADA! You will have to drive around for 15 to 30 minutes while the new ECM "learns" your driving habits...DON'T STOMP ON IT! Just drive like your elderly parents are in the vehicle and you are done. Unbelieveable. Hope this helps anyone else!
ruger1944
03-25-2015 03:14 PM
