power lift tailgate problem
Old 05-23-2013, 12:17 PM
msd26129's Avatar
Default power lift tailgate problem
the power lift tailgate has never worked since i brought the car . when i press the button on fob\inside car i hear the beeps then a click sound then after about 5sec another click . the boot fails to lift ... also i can only open the boot if i use the key by turning it ... if i try and us the release button all i get is chiming sound .
any help would be apreciated
Old 05-24-2013, 04:33 PM
msd26129's Avatar
Anyone ?
Old 05-24-2013, 07:06 PM
mrfixit's Avatar
Lube the latch with a good lube. if you can pull the gate down easily with little to no resistance replace the lift props.the gate is heavy and the motor is small and needs all the help it can get to lift it.
Hope this helps
Old 05-25-2013, 07:46 AM
msd26129's Avatar
the motor doesnt seam to kick in at all ?
Old 05-25-2013, 09:46 AM
TimmyTim's Avatar
Lightbulb
Check the fuse and the wire connector! If all else fails get a motor off Ebay mate
Old 05-26-2013, 06:26 AM
mrfixit's Avatar
There is a module right where the motor is. this determines if the gate is open or closed this could be bad. these are a pain in da *** to repair. if you hear a beeping sound then you are getting power back to the motor. when mine quit in the winter i just went to the salvage yard and bought the whole thing as a unit and installed it.
Hope this helps.
spencerg
09-01-2013 03:34 PM
lidiaw81
01-07-2012 02:17 PM
stewartsoftware
01-14-2011 07:39 PM
Fang
05-05-2008 07:50 PM
midniterenegade
06-18-2007 10:55 PM
Quick Reply: power lift tailgate problem
