rear fog lights
rear fog lights
Hi
My rear fog lights don't work------am I right in assuming that there should be one on each side??
The fog light bulb is the bottom one in the cluster---so any moisture in the unit drops onto the area of that bulb----one is VERY rusty the other side just a little 'white rust'---I am getting a low voltage at the bulb---checked bulbs-OK.
Anyone know which wire going into the cluster is the fog light-?---If I have power to that I may be able to link into the cluster----or tap into it and fit a separate light---I NEVER use the fog light --it is just to satisfy the MOT.
If there is no power at the back-----any idea where I can tap into the circuit ?? (the front fog lights work---do these and rear only work together?)
Nigel & Pamala
Nigel & Pamala
Hi
Nigel & Pamala
Nigel & Pamala
Nigel
