Rough working
the 305 is a number 5 misfire a crank,TPS,map sensor has nothing to do with that code nore does a fuel pump u replace the plugs but not the wires? what about the coil pack?
Did u look up what the code means b4 u spent all the money and time on the above things?
Are you getting consistent spark and fuel injector pulse, when in gear? If yes then check compression.
http://www.obd-codes.com/p0305
