Sliding Door
Sliding Door
Hi all, I have a passenger sliding door that drags metal to metal at the top at the sliding hinge . The door you can lift up and it has movement about 1 inch or so. the other door does not have this. Is this a adjustment issue or is something wore out? Thanks for the help.
David
David
If you have 1 inch free play I'm sure you have a roller away or roller/track come loose. Check one door against the other looking for any parts/track not the same. Think you'll be on your own on this one on here as sliding door adjustments are a dealer trained tech job....If you can find one that is...
dakrt360a
10-04-2013 11:32 AM
Huslayer
01-28-2013 10:14 AM
