Power Sliding Door Adjustment And Diagnosis Aid
Pawl Switch - The pawl switch may behave differently depending on how hard the door is closed. Check the switch reading by closing the latch just to the secondary position, with a moderate slam to full closed (primary), and an aggressive slam to primary. If slamming of the door to primary causes the pawl switch to remain closed when the latch is in primary, Replace the latch.
Full Open Switch - If the full open switch always reads open, check the hold open latch cable to make sure it isn't preventing the hold open latch from contacting the switch. An easy way to check is to remove the hold open cable and then read the switch status with the door fully open. If the cable is impacting the switch status, replace the hold open cable.
Latch Hesitating or Pausing During Cinch - Place the door in the mid point of travel.
Use a screwdriver to place the latch in the secondary position. If the latch still hesitates or pauses during cinch, replace the latch.
