Timing mark/locking postions
Hi all
I am UK and have a 2.8 diesel 2005, I am looking for a work shop manual. This is to help me fit a belt after the belt teeth shredded.
I have had years of exp but left motor trade 8 years ago and am finding it very difficult finding any thing about locking postions of cams, pump crank etc....
Any help would be appreciated..
Nick
Nick
To time it up after a belt snap, you need a set of chrysler timing pins. You use these to lock the engine at 90 degrees after TDC. I've never used the pins, but i think there are 3 of them. One for the flywheel and one for each of the cams shafts.
I assume you have managed to get the injectors out, and sorted out any damaged rockers?
Cambelt off, cam carrier off, 8 broken inlet rockers broken.
All parts ordered, locking pin set too.
Main dealer wanted £3000:00 for job.......then reduced to £2500:00
I have all parts ordered in at under £700:00, thats 16 rockers and lifters too. new belt etc....
Saving £2300:00 on original quote, wife seems we can have an extra holiday as we've saved that much.
Thanks Nick, photos would be great.......does anyone know how he gets permission to upload photos?
Just read your first post, I have a manual that has the diesel supplement in it. I tried to scan and post a page for someone else recently but it was too big. I have pc problems so cant burn a cd but if you PM me I might be able to email it to you. If you need things urgent eg torque settings then just shout.
http://oskin.ru/pub/chrysler-dodge/m...gs_intlpdf.pdf
I have found a manual in a PDF format. if you want more file just cut end of address line....
03-24-2006 01:56 PM
