Sponsored by:
Sponsored by:
Type of coolant for grand voyager 3.3L 2002
Old 11-04-2014, 02:41 PM
jems's Avatar
Default Type of coolant for grand voyager 3.3L 2002
Hi,
Hopeing someone can help and advise me on whichh type of coolant the above Grand Voyager needs.
Some people say orange, others, red and one suggested green!!
Anybody know???
Old 11-04-2014, 03:36 PM
100,000 mile stuff the color does not matter its only dye
Do not use DEX cool GM based stuff the engine will gel up from it.
Old 11-05-2014, 03:30 AM
Leedsman's Avatar
If you have an aluminium-cored coolant radiator, in UK "Comma GO-5" seems to be the one. One presumes the 'GO-5' title means you can go for 5 years. It's not cheap BTW. The same stuff was used in my S-type Jag. Use in 50-50% ratio with water.
You do well to see the antifreeze is changed, once the radiator is plugged up with corrosion, replacement is the only cure. Overheating makes the thermostat jam open too, as it is designed to. All in all, lots of dosh out of wallet.
Leedsman.
voyager_dan
12-11-2014 04:13 AM
Evertb
09-19-2012 02:46 PM
Trent
11
07-23-2012 03:41 PM
muso58
06-23-2006 07:58 PM
muso58
06-14-2006 03:43 PM
Quick Reply: Type of coolant for grand voyager 3.3L 2002
