What Should My Oil Pressure Be At?
Old 03-22-2015, 08:50 AM
rickseminole's Avatar
Question What Should My Oil Pressure Be At?
On a 3.6L Engine using SAE 5W-20 oil, what is a good oil pressure on idle when warm? and how much pressure increase per every 1k RPMs?
Thanks.
Old 03-22-2015, 05:20 PM
Leedsman's Avatar
Historically, a good engine when hot should give around 60lbs/sq" when doing 40mph. or so, 45lb/sq" when idling. If you get 40lbs/sq" hot/motoring and over 15lbs/sq" idling (or at least not illuminating the oil pressure warning lamp) then that's "reasonable". All the quality old cars had oil pressure gauges on the dash-board. If you're buying and the oil-lamp comes on when idling and hot -- don't buy it! Only trouble when buying you don't know how much of that oil-thickening 'glop' has been poured in the sump. The glop is a a so-called viscosity improver, a polymer. It really does do what it says on the tin though.
Leedsman.
billbon8
23
07-18-2011 04:48 PM
gbwiii
01-06-2009 03:48 AM
markr
04-17-2007 09:13 PM
vettman
08-15-2006 11:20 AM
ohare
08-14-2006 10:23 PM
Quick Reply: What Should My Oil Pressure Be At?
