won't turn over
Old 05-18-2014, 04:12 AM
smiler6391's Avatar
Default won't turn over
Hi I have a 54 plate 2.5 se card voyager. Got in it today and it wouldn't start. I've got power going to radio, heaters and everything. All relays click when key turned but it doesn't try and turn over, all fuses are fine. Also tried jump starting that didn't work. But I'm now out of ideas and was just wondering if someone has had this problem before and how can I solve it. Ccheers
Old 05-18-2014, 01:50 PM
tfb's Avatar
tfb
tfb is offline
pull the cover off of the starter relay in the fuse box and try activating it by your finger.
If your's is a manual then there is a clutch interlock switch that means it wont crank unless the clutch is fully depressed. Other than that there's not much other than the relay and starter motor to check. Also check that wire hasn't fallen off the starter motor.
layout of the IPM and where the relay is can be found here
https://drive.google.com/folderview?...0k&usp=sharing
Regards
Richard
Old 05-18-2014, 02:50 PM
I had that same problem a few weeks back. I found that after removing electrical connection on starter coil and refitting it, it started ok and has did since. Just needs a bit clean I sappose and a sqeeze to tighten.
mspieler
Cirrus & Breeze
08-31-2010 07:10 PM
Pause
12
11-18-2009 08:07 AM
edyspunstr
06-30-2008 07:15 PM
jackandh2o
12-15-2007 10:17 AM
gordonblackler
01-08-2007 09:07 PM
Quick Reply: won't turn over
