Originally Posted by voyager_dan
the heater motors will only work when the power button is on
to stop the heater running (under car) set the hot/cold control to 3/4 of the way up then it wont fire up it will only fire up when set to full heat
as for the temp guage it should be around half way therefore you have a inoperative thermostat dont go to chrysler as they will want £140
take a look on that AUCTION site a fraction of the cost and are the same brand as the originals
however they are not the easiest to do i did mine and another forum members car on the same day took most the day to do the pair of them
good luck
dan
Many Thanks for the reply voyager_dan
checked out the auction site thanks for the pointer. I hadn't realised that the thermostat was a complete housing, I had figured on the UK type, domed cover three bolt fixing, pop the dome, pull out the old one, drop new one in, new gasket, tighten bolts
Oh well i guess that's how it goes.
Rite well I think I'm gonna try flushing the cooling system first with some Rad-Flush, then totally drain the cooling system. See if that sorts the problem out. If its still the same then its gonna have to be a new thermostat.
I will post back and let you know the outcome
