Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > Cirrus & Breeze
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 06-18-2007, 06:31 AM
opk opk is offline
Default Aftermarket stereo install - wiring help needed
Hi. I have a 200 Cirrus. I bought it last month with the factory am/fm/cassette and CD changer controls, but no changer. The factory head unit has a joystick control for the fader/balance.
I bought a stereo at a local place andthe correct year/modelScosche wire harness adapter from Walmart. Wired it correctly except did not hook up the amp pwer wire because I did not think the car had a factory amp. The aftermarket head unit has several pre-outs.
The stereodoes not playvery loudlywith minimal bass even at high volume/bass settings, and the front door speakers so not seem to play at all - only the dash speakers and rear deck speakers seem to work.
Its worth noting I bought a factory CD deck from ebay and it plugged in fine and works BUT only the rear speakers work. The seller is going to give me a refund but claims he tested it and it worked fine.
What gives? What am I doing wrong...I just want to play CDs in the car...Thanks...
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 06-18-2007, 08:12 AM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
Default RE: Aftermarket stereo install - wiring help needed
Wired it correctly except did not hook up the amp pwer wire because I did not think the car had a factory amp. U wanted to know whats wrong there ya go.
[IMG]local://upfiles/1033/20086AB29C6248D089A6A300FD9D10A5.gif[/IMG]
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Old 06-18-2007, 06:44 PM
opk opk is offline
Ok...thanks very much...that helps immensely.
Onefollow-upquestion...the wire harness adapter I bought takes speaker level output from the aftermarket stereo to the amp...but an adapter I saw this morining while researching the problem online takes the pre-outs from the aftermarket unit to the amp. Is it ok to take speaker-level outputs and put them thru the factory amp?
I had an Exploder with a factory amp and had to bypass it to run an aftermarket stereo as I recall...so I just want to make sure I haven't or won't fry something.
Tags
2000, 300, aftermarket, amp, chrysler, cirrus, factory, forums, harness, headunit, hook, install, market, stereo, wire, wiring
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
