misfire, 2.5L
Old Feb 25, 2007 | 12:44 PM
mikecahall's Avatar
Default misfire, 2.5L
A few months ago my 2.5L chrysler cirrus started misfiring real bad. I plugged in a scan tool and it read cylinder 2 misfire. I assumed a new set of plugs and wires would fix my problem but that wasnt the case. I changed the plugs and wires and when i started it up it ran like it was supposed to. However i took it out on a main road and got it up to about 55 mph and you could instantly hear it shutter then start missing again. I ran it until the check engine light came back on and then scanned it again for codes. It read cylinder 2 misfire again. When i changed the plugs i noticed oil on the front plugs. So i changed the valve cover gaskets and the seals to keep oil from getting on the plugs. Started it back up and still reads cylinder 2 misfire. I am assuming the problem is somewhere in that second cylinder. I am on a pretty low budget and if anyone has any advice on what I should do next i would really appreciate it. thanks
Old Feb 25, 2007 | 03:47 PM
Default RE: misfire, 2.5L
check compression with all the front cyls if they are with in the same reading then u know its not mechanical. Start to check for possable carbon build up or distuburator issue.
irdaneel
Apr 16, 2008 04:12 PM
1dakota1
Jan 2, 2008 06:02 PM
JJParr
Cirrus & Breeze
Nov 8, 2007 09:09 AM
abiffmaster
Aug 28, 2007 11:00 AM
thesloanfamily
Jun 10, 2007 01:27 PM
