Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > Cirrus & Breeze
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 02-25-2007, 12:44 PM
Default misfire, 2.5L
A few months ago my 2.5L chrysler cirrus started misfiring real bad. I plugged in a scan tool and it read cylinder 2 misfire. I assumed a new set of plugs and wires would fix my problem but that wasnt the case. I changed the plugs and wires and when i started it up it ran like it was supposed to. However i took it out on a main road and got it up to about 55 mph and you could instantly hear it shutter then start missing again. I ran it until the check engine light came back on and then scanned it again for codes. It read cylinder 2 misfire again. When i changed the plugs i noticed oil on the front plugs. So i changed the valve cover gaskets and the seals to keep oil from getting on the plugs. Started it back up and still reads cylinder 2 misfire. I am assuming the problem is somewhere in that second cylinder. I am on a pretty low budget and if anyone has any advice on what I should do next i would really appreciate it. thanks
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
__________________
Michael Cahall
Old 02-25-2007, 03:47 PM
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
Default RE: misfire, 2.5L
check compression with all the front cyls if they are with in the same reading then u know its not mechanical. Start to check for possable carbon build up or distuburator issue.
__________________
Dealer trained Tech 15 years Now Proud Owner operator Kevin's Mobile Repair in ATLANTA. Repairing Chrysler,Dodge and Jeep
KKeller608@aol.com
http://kevinsmobilerepair.com
Tags
2000, 25, 25chrysler, 25l, chrysler, cirrus, codes, cyl, cylinder, cyrus, engine, idle, liter, misfire, misfiring, missfire
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
