Go Back   Chrysler Forum - Chrysler Enthusiast Forums > General Chrysler Forums > Forum Issues
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 03-29-2010, 01:45 PM
Default 2004 Sebring LXi, 2.7, passenger window goes down only...?
Hi all,
Last year I bought 2004 Sebring LXi. So far so good, but... in the last 3-4 months occasionally I couldn't open the passenger window from the Master switch, if there is nobody in that seat. It worked when a person is in the seat. So I assumed that there might be a sensor, which responds only when there is a person there (not very smart though...). Fine.
Yesterday it happened again. So I tried the switch from the passenger side. It opened the window, but it couldn't close it back. Same from the Master Switch. Now the window is half open. The other 3 windows are working fine.
So far:
No noise when it moves down (so the regulator should be OK).
Checked the fuses - all are OK.
I opened the passenger door trim, checked the switch itself - is shows continuity to one of the cables, but not to the other.Assuming that the 2 neighbour cables should correspond to Up and Down. There are 2 groups: 3 and 2, totaling 5 in the passenger door. Don't have any schematics
Tried to switch the cables and make the window to close with Open-command --> no result.
What options do I have to close the window?
Is it the motor... running only in one direction ?
How can I check the Switch? Is it possible to be the Master Switch the problem?
What should I do to disconnect the motor and remove/ replace it?
PS: there is a strange noise when I put the ignition in ON position, which I didn't hear before. Something like ssszzzzdt, very low volume, lasting 2-3 seconds, coming from the control panel direction. No idea if this is Normal or connected to the main issue.
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
__________________
Sebring '04 LXi
Tags
2004, change, chrysler, chrystler, coupe, forum, lxi, motor, passenger, problem, problems, rear, seabring, sebring, window
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
