2009 T&C 3.3 Ambient Temperature Sensor
Old 07-07-2016, 04:28 PM
kandre's Avatar
Default 2009 T&C 3.3 Ambient Temperature Sensor
Does anyone know where can I find the steps or directions for installing the Ambient Temperature Sensor? Diagnosis Code Came up that it needed to be changed. We replaced the Air Intake Sensor but that wasn't what needed to be changed. Also could that cause the coolant to run out Daily? No leaks found. Thank you!
Old 07-07-2016, 08:25 PM
Ambient Temperature is outside air temp how hot it is outside the sensor is in teh vary front look between the grill area.
Old 07-08-2016, 07:57 AM
kandre's Avatar
Okay Thank you! I found it. It's about 98 degrees daily I li e in south Florida
Old 07-08-2016, 02:51 PM
Coolant runs out daily with no leaks?
1. Look harder for a leak. There's a leak somewhere.
2. Check for an internal leak in the engine. Look for oil in the crankcase (motor oil looks like chocolate milk) or a blown head gasket.
gr00vyd0
14
08-29-2020 01:53 AM
Dan Malone
04-26-2020 09:25 AM
wildebeast
02-29-2016 11:45 PM
johnchrisr
10-10-2014 01:19 PM
robwill
03-15-2011 03:50 PM
Quick Reply: 2009 T&C 3.3 Ambient Temperature Sensor
