The dash says "no fuse" and the key remote doesn't work anymore. Also has a red dot on the dash sometime. I checked all fuses I heard it could be some module that went bad just want a lil direction on what should be my next move. Any help is greatly appreciated.
There are two fuses (Green 30A) in a white plastic holder in the underhood fuse box. Pop the cap loose and check those two....
__________________ Professional Mechanic since 1985, Chrysler Dealership Technician since 1999.
We aren't ALL thieves, We're Just trying to make a living like everyone else , So Have A Heart.
If You wanted Dealership Service, You wouldnt Go To "Discount Quik Lube" , So why did you Walk into a dealership Expecting QUIK LUBE PRICING????
Ma'am, It costs so much money, because ...I CAN, And you CANNOT, And It matters Not to Me, Because I HAVE A RIDE HOME.
3/36 Does not mean 3 years and a day, or 36,001
A nO FuSE message indicates that IOD voltage has been lost. That white plastic holder contains The fuses to control IOD functions...
"IOD" Class is about to begin....
Radio, computer, interior lamps and various modules all use asmall amount of battery power, even when the car is turned off. During shipping and storage, that battery power is disconnected by lifting the "Ignition off Draw" connector in the fuse box, to prevent the imminent discharge of the battery over time.
Go thru the car and tell us what else does not work....
The blinkers won't stay on unless the car is running. from the inside the car doors won't open with the door switches unless the key is in the ignition in the run position or start position.
All that still works fine though the radio won't shut off right away after taking out the key it takes like 10 sec. Unless I open the door or turn radio off manually
You have an open splice somewhere in the dash harness, where the IOD line Branches off....
It is fixable, But You may want to consider professional help at this point.
