Go Back   Chrysler Forum - Chrysler Enthusiast Forums > General Chrysler Forums > General Tech
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 06-09-2011, 06:52 PM
Exclamation '07 Pacifica-Please Help
2007 Pacifica-Had Chrysler remanufactured transmission installed by transmission shop. Car ran fine, but there was oil leaking. So ~ 1 week after the trans was installed, I DROVE the car back to the shop. They replaced the R/S Cam Shaft cover/gasket, but since then the same side cylinders will not fire. Had it towed to dealer (I originally Drove it into the shop). Dealer has had car for 3 days, and can't determine issue. Modules have been replaced.. timing is fine.. compression on all cylinders 200..no power coming off the alternator, they don't see any wire issues. Dealer has been told by chrysler to pull cylinder head off to make sure that Trans Shop didn't cause issue by installing Cam Shaft cover incorrectly.
... Any ideas I can suggest to the dealer... I'm into this for thousands of dollars at this point. Thanks
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 06-10-2011, 07:15 PM
Try unplugging the Ignition Capacitors, Located on Either bank, Mounted To the Fuel Rail bolts. It can Pull Down ASD voltage To Coils and Injectors, to the point that they dont work.
__________________
Professional Mechanic since 1985, Chrysler Dealership Technician since 1999.
We aren't ALL thieves, We're Just trying to make a living like everyone else , So Have A Heart.
If You wanted Dealership Service, You wouldnt Go To "Discount Quik Lube" , So why did you Walk into a dealership Expecting QUIK LUBE PRICING????
Ma'am, It costs so much money, because ...I CAN, And you CANNOT, And It matters Not to Me, Because I HAVE A RIDE HOME.
3/36 Does not mean 3 years and a day, or 36,001
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
