Go Back   Chrysler Forum - Chrysler Enthusiast Forums > General Chrysler Forums > General Tech
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 01-22-2011, 04:00 PM
Default 95 cirrus won't start
95 cirrus, 110k miles. started car, left running to warm up, was stalled when i came back out to leave. won't start. Cranks but no start.
what i know: fuel pump is running. It's getting gas
Plugs were checked, oil in tubes. This was cleaned out and plugs replaced. Timing belt appears to have been replaced.
They checked distributor and rotor, cleaned up and put back. Looked ok
It has spark. Ether doesn't work
Compression very low.
o2 sensor taken off to check if cat converter plugged still no start.
It hasn't had much heat, thermostat probably needs to be replaced. I read somewhere that another person had no start problem and it turned out being the thermostat was bad and it wouldn't circulate antifreeze so car wouldn't start. Does that make sense at all?
Any ideas?
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 03-21-2011, 02:36 AM
compression low as in less than 100psi? even if you had low compression with the use of ether thru the intake not thru filter housing engine should pop as long as you have spark.
My BET is that you HAVE WEAk OR NO SPARK. start looking in the ignition circuitry.
Old 03-21-2011, 04:02 PM
TNtech's Avatar
ABSOLUTELY HELL NO.....LOL
Assuming this is a 2.5L V-6
__________________
Chrysler-Jeep-Dodge Technician
Electrical & Driveablity
Crossfire
Tags
1999, 95, batter, chrysler, cirrus, dead, fire, gas, heat, hot, problems, spark, stalled, start, starter, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
