Car Wont Start
Old 07-25-2016, 01:06 PM
Adamfal's Avatar
Default Car Wont Start
Chrysler pacifica 2008 4.0 awd Sig. Series
If it is a hot day outside and my windows are
closed my car doesn't want to start...I have to then open the windows and wait between 45 min to 1 hr 25 min and then the car will start.
If the windows are opened already the car will start.
All the lights and power work in the car. I have already changed the battery and the ignition and also the starter
twice. Is there some type of sensor or ignition relay
inside the car preventing it from starting when the
inside gets too hot with the windows closed...my
mechanic doesn't know what to do anymore
please help!!!
Old 07-25-2016, 09:22 PM
any codes present in any of the computers? Your will need a good scanner to see something like this.
Old 07-26-2016, 12:17 PM
Adamfal's Avatar
No codes are coming up for 2008 pacifica
I am thinking about replacing the tipm...
Are there any fuse boxes inside the car because I can't find any. That seems like a logical explanation since something inside the car is getting too hot with the windows closed not letting the car start
Old 07-26-2016, 09:58 PM
The tipm is under the hood so that theory is tossed out teh window.
And what scanner did you use to check for the codes in all the computers?
Old 08-06-2016, 03:11 PM
Adamfal's Avatar
My mechanic uses the standard scanner and no errors are coming up...
Well I had an extra ground wire put on my battery yesterday I was hopefull that this will solve my problem...
Today I left my house at 1130am to go to home Depot and the car started right up...I was amazed because the car was sitting in the sun for a few hours now with the windows closed...
So I'm in home depot for almost an hour...get in the car to leave but it doesn't start...all the power works as usual but it just wont start...every ten minutes I would try to start it again and finally right before I was going to call a tow truck it started....1 HOUR 10 MINUTES LATER
I guess the extra ground didn't help...does anyone have any more suggestions???
Someone also told me it might have something to do with the ANTI- THEFT RECEIVER??
Thankyou anyone for you time and input
Old 08-06-2016, 11:43 PM
i gave mine which is the shortest and most effective way of getting to the bottom of the issue.
Old 08-09-2016, 03:47 PM
Adamfal's Avatar
Well today my mechanic replaced the ignition housing...He showed me the bad part and there was a Crack in it that he said probably wasn't making a proper connection...I hope this works I will test it out the next few days
Old 05-05-2018, 09:25 PM
prettijazzy's Avatar
Default was this a fix
did this fix your issue? replacing the housing?
ekhealy
05-23-2011 10:47 PM
peterjv
04-21-2011 12:45 PM
bentlawrence
02-04-2011 08:42 AM
sebringgirl
05-27-2010 11:47 AM
sebringgirl
05-20-2010 11:58 AM
Quick Reply: Car Wont Start
