Hey, keep it this thread. You have like 3 others. The cam sensor IS basically the distributor itself. Crank sensor is on trans end of engine towards the back. It pokes through a hole in the transmission bellhousing and has ONE 10MM head screw holding it in and a 8 inch or so pigtail hanging off of it.
NO..the COUPE is a totally different pig. Basically same engine but different electrical system. From your first post sounds like typical crank sensor malfunction.(of course i'm not there to see the data and the DTCs) Make sure you seat it right when you install the new one. There SHOULD be a little wafer on the tip of it to set the air gap. Press it in firm when tightening the screw but don't lay on it with gorilla force. And don't let your spark plugs and wires get old. That's how distributors get killed. They are NOT cheap.
__________________
Chrysler-Jeep-Dodge Technician
Electrical & Driveablity
Crossfire
