I bypassed the ASD relay & got power to one side of injectors but no spark or injector pulse.According to what I found on Alldata(went to library),the ASD relay won't energize until it "sees" a crank & cam inputs.So it does not energize(ASD relay).I don't have a scope to check the cam or crank wave patterns,so I'm stuck.The problem can be 3 thinks-bad distributor,bad crank sensor or skipped timing belt.There could be a broken wire but haven't seen any during my time under the hood.I decided to replace crank sensor as its cheaper than the distributor & the distributor looks fairly new.The crank sensor is original & a small piece is stuck in the transmission
I broke the sensor trying to remove it.I was very careful but its cold in my garage & the sensor never been removed.I plan on punching the small bit into transmission(flywheel area) & will remove inspection cover for torque converter to retrieve the small piece.It is a PITA to get at this sensor
I hope this fixes the car.I hope I don't have to sync the cam & crank sensor as I don't have that function with my cheap scan tool
Any others think this will fix it?Any suggestions
