Seat Belt Retractor Replacement??
Just curious is the seat belt retractors or anything seatbelt related something that is covered by Chrysler?
If not anyone know if there is a special procedure or tool used to remove and replace a seatbelt retractor that is located in the back of a rear seat?
I am used to most that are on the pillars and those usually are just bolted down but this one is in the back of a removable seat and I cannot see any bolts etc. I do see what appears to be a hook or so on the top of it so I am assuming there is some tool to unlatch it from the backing plate it is attached to.
I sure hope someone can help I told this girl I would look into it and I posted some ?? In the PT cruiser section like 8 days or more ago and no one has even made any comments or anything in that section since 9-2.
What's up is this forum going south or something??
2004 PT Cruiser, it is the rear Middle Seatbelt, The one of the 2/3 size removable seat.
First it would not retract and then me being the I can fix it guy I got it to retract (Manually retracted it) now it will not release LOL. I am pretty sure it needs replaced, But I cannot figure out how to disconnect it, I believe by what I can see it must use a special tool to unlock it from the mounting bracket as it looks like there is a a latch like thing securing it but I may be incorrect.
