having stalling issues notice it hestitates
Hi i have a cirrus ive been recently have stalling issues at stop lights and when does stalls it doesnt start back up for like 5 tries there was a check engine and code was P1391 intermitten condition, so here is some history ive currently replace camshaft sensor and crankshaft sensor about 4 months ago took to regular mechanic and he not sure any advice would greatly helpfull...
causing headache
causing headache
re mileage
sorry its a 2000 chysler cirrus 2.4 it has about 144000 mileage maybe had the engine replaced last year to a used one no really sure on its mileage
when it does stall its after its been hot when its cold it doesnt sct that way
Since the car is a 2000 model year it really is not that old. I'm not sure exactly what it is by your description of the problem. Sounds temperature based though whatever the problem is. Are there any check engine lights on and have you had someone check the check engine light code? Any check engine light code helps narrow down the problem in a hurry.
My daughters Mazda 626 had a check engine light on with an EGR valve code(Auto Zone checked it for free). The guy's on the Mazda forum said that most likely it was the throttle body was dirty/gummed up and that the EGR valve did not need to be replaced due to they rarely ever go bad on the Mazda 626's. I cleaned out the throttle body with throttle body cleaner, sprayed the air/oxygen sensors off with sensor cleaner, put a new throttle body gasket on, put everything back together and the check engine light went off. The Mazda ran better too. This was a $20.00 fix.
I mention this due to your problem could be some sensor being dirty or bad.
thanks the check engine light comes on and had checked at autozone and they coded at P1391 CMP or CKP intermittent condition.
also the check engine light does go off on its own was told it does that after 5 starts
missb2004
12-09-2013 10:40 PM
woodlin321
10-08-2008 09:43 PM
