Other Any other Chrysler within.
1992 LeBaron engine question
Old 10-22-2015, 11:59 PM
ChryslerLeBaronLove's Avatar
Default 1992 LeBaron engine question
Just bought this awesome convertible and everything works but the valve covers leak bad. Is this an easy fix? Also, my odometer doesn't work but speedometer does. What's the best way to fix?
Old 10-23-2015, 08:06 PM
Try tightening the bolts that hold the valve covers down. With age, the gaskets can shrink. Be GENTLE and don't overtighten the screws. They are small screws and might break if you overdo it. Also, if you overdo it, you can distort the valve covers and make the problem worse.
If that doesn't work, you'll be needing to replace the gaskets, which involves removing the valve covers, cleaning the sealing surfaces, installing new gaskets and putting it all back together. See if you can find a Chilton's or Haynes manual or similar. Read through the relevant chapter and then decide whether you and your toolbox are up to the job.
Old 11-30-2015, 09:36 AM
marty mopar's Avatar
speedometer: the odometer gear is a available aftermarket
RacingJunk
04-19-2015 08:39 PM
Gramkracka
Other
09-23-2010 04:33 AM
yox
10-05-2009 08:43 AM
Mashashin
08-04-2008 03:09 PM
1992lebaron
12-19-2007 03:46 PM
Quick Reply: 1992 LeBaron engine question
