Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > Other
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 12-05-2005, 07:00 PM
Default HELP! 89 Lebaron Wont Start, fault codes
Hello. I have a 1989 Chrysler Lebaron 2.4 ltr. It will not start. A few months ago it started idling high at 2.5 rpm, going up to a maximum of 3 rpm at about 100 km/hr. I drove it like this anyway, since adding some fuel injector cleaner seemed to bring the idle down a bit, (to 2 rpm), and the car still worked, up until now.
I did check the trouble codes using the key sequence and got the following error codes (in this order):
12, 44, 37, 25 ..............After looking up the codes I find they are listed as the following:
12: battery recently disconnected (not important)
44: No FJ2 voltage present at logic board
OR 44 Logic module self-diagnostics indicate problem
OR 44 Battery temperature out of range
37 part throttle lock/unlock solenoid driver circuit (87-89)
25 Automatic Idle Speed (AIS) motor driver circuit shorted or target idle not reached, vacuum leak found .
Now the car will not start. The only thing I noticed different is that a day prior to this the idle was chugging a little bit, going below 1 rpm and then fluctuating up and down to 2 rpm. It was making ticking noises from somewhere in the front end just 1 hr prior to the not starting problem. The cat converter is separated a bit from the manifold, but it hasn't caused any problems before other than noise.
We boosted the car thinking it might be the alternator, it finally did start after an hour of turning it over. It almost sounds like it wants to go but isnt getting any fuel, though the fuel pump does kick in when I attempt to start it. Check gauge light comes on when attempting to start. After it started we took it for a spin and it chugged violently until speed reached 100. Barely got it in the driveway as it kept stalling. Antifreeze blew out all over the engine. (there is a small hole in the rad near the top, but it never blew out before). Idiot lights state the car did not overheat, but came close. Now it will not start up again...same problem. All fluids are topped up.
Could this be caused by the fault codes I received, and if so why did it run all summer and now wont start? How can this be fixed?
Update... Checked the oil, no sign of the chocolate milk it apparently looks like when theres a head gasket gone, and the antifreeze wasn't frothy either. I unplugged the battery to reset the computer, and am now getting all the former fault codes, plus a new one....43: cylinder misfire (according to Chrysler codes) SIGH......
Could all this mess be caused by dirty injectors, a faulty spark plug, or distributor ? I'd just like to get the car started so I can get it to the city to a shop....Thankyou very much.
cc
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 12-12-2005, 03:27 PM
Send a message via AIM to JXI101 Send a message via Yahoo to JXI101
Default RE: HELP! 89 Lebaron Wont Start, fault codes
wow... sounds like you're having a rough time. sounds to me like the whole thing is just f**ked... could be a number of things honestly, and I say you're better off towing it to a shop. find someone you can trust though. Mechanics will rip you off bad so be careful, but you need to get this thing over there or call one of those mobile mechanics to come look at it... I dont know what it is, sorry, borrow a friend's pick up and some tow straps..
__________________
http://www.mikestshirts.com/images/so14.jpg
Southern by the grace of God!
Tags
1989, 44, 87, 89, board, chrysler, codes, diagnostic, fj2, lebaron, logic, present, start, voltage, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
