Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Past Chrysler Models > Other
Sign in using an external account
Register Forgot Password?
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
LinkBack Thread Tools Search this Thread
Old 12-19-2006, 05:31 PM
Default Various Lebaron Problems...Need Help!
I recently bought a really nice 58k mile Chrysler Lebaron convertible. The car was very well cared for, but was sitting for quite awhile and now the car has some issues. This is where you come in.
1) The transmission is the bullet-proof Torqueflite 3-spd. auto. When shifting from any gear into Reverse, it shifts very hard and sounds awful making a loud CLUNK noise. I know it shouldn't shift as hard as it does because I've owned two past Chryslers with this same engine and transmission and they shifted into reverse much more smoothly. The transmission shifts perfect going down the road into all forward gears. The owners manualrecommends having the trans. fluid changed and bands adjusted every 15k miles.Will having these bands adjusted fix the hard Reverse shift?
2) Between 1500-2000rpm, there is an audible grinding metal noise that comes from the engine bay.It kind of sounds like a worn out bearing. I was told by amechanic that it could possibly beone of the pulleys wearing out, which is causing a belt to squeal too. Is this common and what is thereal problem to fix?
3) Onemorning, I turned my windshield wipers on and they worked fine for about 5 seconds, then began to make ametal clanking noise, resulting in the driver-side wiper arm stopping midway and the passenger-side wiper continuingto operate as normal. I disasembled the cowlpanel and foundtwo disconnected black metal rods lying inside.Thereare no broken pieces that I could find and nofasteners of any type to hold these pieces back in place as they should be. So how doI properly fix this and what parts should I need?
4) Lastly,both front seatsbacks are not locking in place as they should be. Withvery slight pressure, the front seatbacks flop forward without using the releaselever located on the lower, outboard sides of the front seatbacks. Both of these levers refuse to lift up likethey should, as if they are locked or frozen in place. Iremoved the plastic covers on both seat mechanisms and found no apparently damage,broken, or missing pieces. What the hell is going on here and how doI fix them so the seats lock in place like they should?
[IMG]local://upfiles/2274/FF37CB19EEEC40D2A08A8CF013A7A8A3.jpg[/IMG]
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
__________________
palebeachbum
Tags
91, chrysler, cirrus, common, engine, grinding, grinds, knock, lebaron, loud, lower, makes, noise, problems, quiet, reverse, sound
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Featured Sponsors
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
