Hi,
Ok.....the oil filter is up behind the engine on the left side (as viewed from the front) You won't see it until you take the underside tray off and get right underneath and look up.....but its pretty easy to reach once you're under there!
Fuel filter is underneath the car at the back.....jack it up at the back and crawl in from the rear bumper....you can't miss it.
Timimg belt interval is a bit more complicated.
01-05 Model Years Is 60,000 Miles or 5 years, whichever is sooner
06-07 Model Years is 100,000 Miles or 8 years, whichever is sooner
(Both idler pullys should also be replaced at cambelt service)
Your's should be the latter of the intervals, but as you're on the borderline, if I were you I'd check your chassis number with a chrysler dealer and get them to advise.
