00 300m TCM
Old May 11, 2011 | 12:29 PM
jward55's Avatar
Default 00 300m TCM
i have a 00 300m and my check engine light came on so i had autozone check it and the said that my TCM is going out and, so i went to the junk yard and pulled one from a 99 intrepid but my car has an auto shifter and the car i pulled dosent, so i found a 05 intrepid with an auto shifter i was told that the intrepid parts were compatible with my 300m how do i know if one of the TCMs i pulled will work for my car
Old May 11, 2011 | 06:46 PM
your first mistake is to rely on on a parts supply place to tell u whats wrong with your car do u go to a food mart for medical help or do u go to a DR that is trained in this situation.
What were the codes from the check engine light?
Old May 12, 2011 | 06:45 AM
jward55's Avatar
The codes were: P0700, P0731, P0720, P0118
Old May 12, 2011 | 08:27 PM
Djinn-n-Tonic's Avatar
This is PRICELESS.......WE techs Bust our ***** all day long to figure stuff out and we ae called thieves at least 3 times a day........But some monkey with a universal code scanner has you running around town buying unnecessary parts , because he has NO CLUE.....
Gotta Love It.....
Now..... First things first...2005??? Intrepid doesnt exist ...so thats out.....
731 is a Gear ratio error, followed by 720 which is an Output speed Sensor CKT failure.
Think........If output speed is Invalid...How does a trans controller pick the correct ratio???? Fix the 720, and 731 will probably go away all by himself.
118 is a coolant sensor code....Simple enough to check....It indicates an Open CKT....so if the wires arent broken, and PCM isnt fried....The sensor is bad. The easiest way to do this...is to unplug the coolant sensor, and short the terminals with a paper clip....If the code goes to 117, or shorted...you have found your problem.
TAKE THE TCM's BACK.....If they let you....and spend that cash to have someone COMPETENT look at your car!!!
Old May 13, 2011 | 03:41 PM
tinman's Avatar
Nicely stated, Djinn-n-Tonic.
Old May 14, 2011 | 07:46 AM
jward55's Avatar
Ok ill start with changing the speed sensors now my next question is where the heck are they? can someone post a picture of their location
Old May 14, 2011 | 05:49 PM
NO YOU WONT!!!!!!!
You will start with checking the wiring between TCM and trans.....
Location
TCM PIN OUT
Measure resistance between pins 13 and 14 of TCM connector... and Post back.
renrodb
Jul 24, 2009 07:47 AM
Zuma68
Jul 20, 2009 08:42 AM
dengen
Aug 21, 2008 06:48 AM
MagnumSRT8
Dec 30, 2006 05:42 PM
94_LHS
Aug 21, 2006 09:47 PM
