03 Concorde Rotor Question
Should the front rotor on my 03 Concorde be able to wiggle 1/4 inch or so on the side opposite the caliper? If not, could this also be the clunking I'm hearing under slow speed straight line and/or cornering braking?
The play you speak of seems normal. The noise could be strut mounts, motor mounts, exhaust mounts, something rolling around in the trunk even. Its hard to track these down sometimes. depends on mileage and how it has been cared for.
Yep, confirmed that it was normal. Leaning towards sway bar end links as the next thing to check.
Please post back your findings... Good Luck!
Sorry for no update. About a month or so ago, I had it looked at and was told that the pass side lower control arm bushings were shot as well as all of the subframe bushings. Are these things I can change without air tools?
