1997 lhs 3.5 p0306
As title say p0306 cyl 6 misfire. Only misses for about 15-20 secs and only after setting over night. But it will eventual turn on check engine light. 168,000 miles new plugs and Chrysler wires 6 months ago. Replaced number 6 plug and wire again. Ran wire over intake plenum. Have checked for vacuum leaks get no hint of a leak. Went so far as to plug off the brake vacuum line. Still a miss for a few seconds only on a stone cold start. Did a power clean on the injectors. That did keep the light off for about 3 week. After the initial start up miss it runs perfect. I am pretty much at a loss. Any ideas. If I do have to pull the plenum I will put in new injectors. I do have a new coil pack may try that. Any ideas |
Sounds like you have #6 cyl. leaking down overnight(not holding system pressure). That will partially flood that cyl. on initial start and the injector should be replaced.
Better to test the injector to see if it is leaking before condeming it. Don't replace parts unless you know it is bad.
