2000 300M, missing,
Old Sep 24, 2012 | 10:39 AM
mainlandislanders's Avatar
Default 2000 300M, missing,
Hi. We have a 2000 300M, the engine light came on, then started to flash. Now she misses when you drive. We replaced the plugs, no change. The older plugs were burning equal and nice color. Then put in some fuel cleaner, thought the injectors were dirty. But so far still the same. Then just now, sitting in car revving it to 2000rpm, turned the power on for heater(no fan on) the car started to rev up. Now really baffled, what could be the problem? Don't want to spend too much in-case..............HELP
Old Sep 24, 2012 | 12:06 PM
what are the codes for the light?
Old Sep 24, 2012 | 04:40 PM
Default 300M missing
We didn't do any checking for the light. I keep hearing people saying something about twittling with the key to get a code. Is there a way? If yes how do we do that?
Old Sep 24, 2012 | 11:03 PM
turn the key on and off 3x 3rd time leak it on position and codes will be displayed where the miles are.
Old Sep 25, 2012 | 10:57 AM
Hi, we tried the key thing and nothing came up. Did it a couple of times. Now I am really lost.......
Old Sep 26, 2012 | 12:51 PM
Default 300M missing, got codes
Hi we tried the key thing again, we had to do it about 7 times before they came up......
we got P 1684
P 0340
P 0301
Please help............................
Old Sep 26, 2012 | 01:38 PM
the 340 is a cam sensor issue and the 301 is #1 misfire
Old Sep 26, 2012 | 04:44 PM
FIREM's Avatar
LH platform cars are very sensetive to system voltage.
1684 indicates battery disconnect in last 50 starts. How old is your battery? If close to 5 years old it is due for replacement. Terminal connections at the battery and jump post under the hood need to be disassembled, cleaned and reassembled on occation. Even if thy "look good" need routine cleaning. This can cause a misfire condition due to low voltage.
If it constantly misfires you can islolat it by disconnecting the signal to the coil and see if it runs the same or worse to isolate to one cyl.
How old are your plugs ? Book says 100k but 70-80k is more reasonable life.
Once you clean the battery connections see if the codes come back . If 0340 persists, change the cam sensor. Use OEM dealer part. Aftermarkets don't last.
Old Sep 26, 2012 | 08:25 PM
Do not mess with your battery If u do any of the above it will erase any and all codes and information pertaining to this issue and that will make it that much harder to figure out whats wrong.
The 1684 code will be in just about every single Chrysler car known to man its a null code has no meaning.
keats34
14
May 23, 2022 02:50 PM
cchpounder
Aug 17, 2015 11:31 AM
jameslee522
Oct 18, 2007 04:24 PM
jameslee522
Oct 14, 2007 08:05 AM
Dec 23, 2005 03:57 AM
