2000 Chrysler LHS power seat front driver’s side.
The seat back fell to the full recline positionand will not return to the upright position I can move the seat back by hand to the up position But it will fall back to the recline position. The motor works. I can feel the shaft on both sides of the mortar turning but the screw shaft leading to the back of seat will not move. What do I need to fix this? Dave |
Take the seat out (not ness but you will understand )
pull away the skins( velcro and plastic clips) Now you will see the broken bracket,push back in place and weld solid! Now stay away from the drive through! |
Originally Posted by gn300
(Post 37792)
pull away the skins( velcro and plastic clips) Now you will see the broken bracket,push back in place and weld solid! Now stay away from the drive through! The motor works but the screw shaft on both sides of the seat that comes from the two nylon gear box and goes to the back of the seat will not turn. I suspect the two nylon gear boxes are wormed out.(not sure). JD |
Originally Posted by jd6158
(Post 37798)
I have taken the seat out and checked the motors and for broken parts. Could find nothing broken
