2000 Concorde LXi Rear Hub Nut Size?
Does anyone know what size socket (deep socket?) I need to remove the large nut from the rear axle stub holding the hub/bearing on?
And I pull the hub/bearing off, does it have to be pressed back on? Or can I use the right diameter socket to tap it back on? TIA |
Socket Size
36MM worked. And it didn't require any puller or to be "pressed" on.
