2002 300m compressor seized
Toward the end of last summer I noticed my AC wasn't getting very cold so I brought it in to my mechanic and he recharged the system. It worked for about 2 weeks or so and then lost its cool again. Since the summer was over and the temp had dropped I decided to leave it as it was and see if I still had the problem next season. At worst I assumed I had a leak which could easily be repaired. As the problem still remained this year I brought the car back in 2 days ago and I was told my belt snapped and the compressor seized and needs to be replaced. I was quoted at around $500 for a new Chrysler compressor and about $335 for a used one. Labor cost to evac, install, and recharge would be about $350ish as well.
My brother in law owns a few auto parts stores and told me he could get me a brand new 4-seasons compressor for $180 and can have the entire job done with someone he knows for around $350-$400 total. If not, he can just get me the part and I can have my mechanic do the rest. I really know nothing about this and could use some advice. Should I go with a new or used original Chrysler part or is an aftermarket compressor just as good? Do you guys know anything about 4-seasons compressors? Is there a reason I shouldn't go with that part? Do you think $650 is a fair price for the new 4-seasons compressor and labor? |
Personally I would just rip the old compressor out and ditch the AC all together, it's useless..that's what windows are for.
But I would be confident that a non-OEM AC compressor would be fine, it's not like your car is under warranty or anything. Plus you save some serious coin. I wouldn't spend $650 for AC, I would go for the 4 seasons :D |
u come live in a place like GA for FL for one summer u will change you mind about AC
Living without AC is NOT an option. I decided to go with the 4seasons compressor and the entire repair plus the part cost $500. I think I got off relatively cheap. Hopefully I don't also have a hole in the line and have to recharge the system if it leaks out.
So 1 year later and the AC is blowing hot again. Seems like the compressor is running fine. Is it normal for the AC to need a recharge again after only 1 year? What is the next step? I don't want to have to charge every year.
nope there is more then likely a leak some where
(Post 51911)
What do you guys think is the best course? What is the average life expectancy on the 2002 300m? |
call around your local area for quotes
