3.2 driveability issues
My wife broke her car tonite...2001 concorde 3.2. My wife said the car ran normal this morning until she got close to work. The car starting spitting an sputtering. I drove it this evening. The car was missing really bad an surging at stops. I got my foot in it a little bit an all it did was backfire out of the fuel injection. I would say just a minute later the car died an would not restart. I did try an restart it which it didnt. The check engine light is on well was on.. Its throwing a code via cycling the key P1391. Ive looked it up an not sure what it means. Any help would be appreciated as my own vehicle is now broke so we have 2 broken vehicles in the same nite an live out of town. Kinda screwed here.
P1391-INTERMITTENT LOSS OF CMP OR CKP
Possible cam or crank sensor or timing belt is broken and or stretched about to break. |
Ok thanks. We are going to put it in the garage tonite and start looking at it.
Is there a way to inspect the timing belt without taking it apart. you know such as a inspection plate or cover?
You're going to have to take that front cover off to see the marks. It's not as hard as it looks. Take off the belts and the tensioner with the 3 13MM bolts holding it on. After that it's all 10MM bolts and one T-30 torx on the passenger side.
Yes its been awhile...my jeep gc went down also..so ive been working on that. Swapping over to a 5 speed...thats almost done. Time to start researching her car again....
Does the 3.2 come out from the top or the bottom? |
she locked up the motor?
(Post 57482)
are u required to core the old engine? I need a 3.2 or 3.5 to rebuild
(Post 57495)
No we dont have to core it. Its a 3.2 309-831-81seven three give me a buzz, my name is Brian |
