94 concorde
no power to fuse # 17, no wipers dome lights no ATC no gauges, Air bag light stays on. checked fuse box under hood and all fuses and relays have power to them. 12+ volts no alarm light in the top of dash. car still starts and runs like normal just the above mentioned. any suggestions, thanks.
Ignition switch
ok just curious when i turn key to first position some of the idiot lights come on and then when i finish turning to the on position then the rest of idiot light come on
yep it will do that
Just to let you know it was not the ignition switch. It was the body control module. thanks for your help though.
the BCM has nothing to do with a no power to fuse 17. Did u do the work yourself or have some one else do it?
Had the work done at the local dealer.
so you got charged for a bcm and an ignition switch then correct?
No, they did the troubleshooting and informed me that the bcm was bad. They also informed me that it was no longer avaible through chrylser. I went online and found one and installed it myself and it solved the problem. The key switch is still the one from the factory install.
