95 Concord no start
Hello,
I have a 95 Concord 3.3L 90k miles that will not start.When it is cranking the low oil pressure light comes on, and stays on, while ignition is on. I have replaced\checked the following: Crank sensor: new Cam sensor: new Spark Plugs: new Spark Plug wires: new Coil pack: new PCM: different one from junkyard: no change Getting spark: yes Fuel pressure: checked at around 50 psi Tried starting while in neutral: no change Battery charged: yes MAP sensor: disconnected no change ASD: not checked yet O2: not checked yet Coil pack: Getting 12V at B+ Codes: 12 (because battery was disconnected) and 55 (end of codes) Oil pressure sending unit: Plan to change. Fuel filter: Plan to change Oil and oil filter: Plan to change When I pulled the plugs after trying to start it, they are wet with fuel, probably because it is cold out 40F and it is a rich mixture at start up. Any ideas would be very helpful. Thanks Chuck (a newbie) |
RE: 95 Concord no start
need to have some one that knows what they are doing look at the sensors and adaptive numbers.
