Can outer boot on transaxle be replaced? - '99 300M
The outer boot on trans-axle (front, left) is torn, some of the internal grease has leaked. Is it possible to replace only the rubber boot? If so, how laborious would it be?
boot replacement
you could get a split boot and put that on. It will work for a little while, I've never really had very much luck with them. I normally remove the half shaft (axle) and replace the boot..
Originally Posted by dadh68
(Post 28404)
You have to disconnect the ball joints and remove the steering knuckle. It's a big job.
