Concorde 3.2L shifting rough after warmed up
My Concorde LXi 3.2L is shifting rough but usually only after the engine has warmed up.
I checked the transmission fluid after the car was warmed up and idle but the level was good. Also, the fluid color looked good, and it doesn't have a burnt smell. What could be causing this? Thanks, |
How many miles and has the fluid been changed? ATF+4 is a must in these cars. Fluid level also critical. Full "HOT" is when the tip if the stick is to hot to hold.
Pull the fuse Pre 02 Q, 02 and up N (under hood fuse box) to reset the adaptive shift patterns learned while driving. This may cure the harsh shift issues |
Thanks for the reply firem! The car has 75,000 miles on it. I jus recently purchased the vehicle used so I am not sure as to the last tranny fluid change, so I guess I should have it changed no matter what. I just figured it was fairly recent since the fluid has a nice pink color to it.
Forgive me for my ignorance but I checked the fused box under the hood and I didn't find any fuses labelled as you stated. Are those the labels for the fuses or should I be looking for something else? Thanks Btw, my concorde is a 2000 lxi 3.2L |
concorde hard shift
I have a 2000 concorde lxi and it has a hard shift just from 1st to 2nd and the fluid is new. it has 193k on it but I am ase certified. and have a full shop. so if you could help me out it would be grateful. I have done so much just to keep this car rolling on the road. I would just like to know if this means a new trans. or if it is something that can be fixed. ty
