Dripping Water inside
Hello folks, I read something like this in the past here
but cant find it. Here is what happend, any time that you turn on the heater or AC some water start dripping on the passanger side, from under the dashboard. Noticed that both AC or Heater works perfectly. As long you dont you the heater or AC there is no dripping....... Thanks [8D] |
RE: Dripping Water inside
Possible heater core with a small leak, but it sounds more like a hose issue.
Regardless, you will need to take the dash apart to see the issue which is no easy task. I like to do things myself, but I woul dhave problem paying a mechanic to do this... |
Regardless, you will need to take the dash apart to see the issue which is no easy task. I like to do things myself, but I would not have a problem paying a mechanic to do this... |
