No Heat but not overheating
Old Oct 9, 2014 | 08:05 AM
300M Chic's Avatar
Unhappy No Heat but not overheating
On Sunday I replaced my battery. Everything was working just fine. Monday morning I went out to start my car and there was no heat. There is cold air blowing out of the front vents but there is nothing blowing out of the defrost vents up front. The Rear Defrost works just fine. I made sure there was plenty of coolant also. Please help!!!
Old Oct 9, 2014 | 08:08 AM
300M Chic's Avatar
Also it is not overheating and the temperature gauge is reading in the middle like it always has. I dont think its the thermostat but I really have no clue.
Old Oct 9, 2014 | 11:39 PM
a thermostat would make the engine over heat why did u replace the battery on sunday?
Old Oct 10, 2014 | 06:00 AM
300M Chic's Avatar
It randomly wouldn't start so I changed the battery.
Old Oct 10, 2014 | 09:27 AM
was a check engine lite on?
Old Oct 11, 2014 | 06:30 AM
300M Chic's Avatar
No the ch
Old Oct 11, 2014 | 06:31 AM
300M Chic's Avatar
The check engine light was not on
Old Oct 11, 2014 | 04:21 PM
FIREM's Avatar
May need to to recal the ATC
RECALIBRATING YOUR AC:
1. Start the engine but do not move the vehicle.
2. Set the Temp control to 75 degrees.
3. Press and hold the Floor, Mix (vent/defrost) and Defrost buttons at the same time. The floor is a bottom button and the others are upper.
4. The control head will begin to blink and enter a diagnostic mode.
5. Release the Floor, Mix and Defrost buttons.
Old Oct 13, 2014 | 11:40 AM
300M Chic's Avatar
Thank you. I will try this next.
Old Oct 15, 2014 | 04:32 PM
300M Chic's Avatar
Ok I tried that and the number 24 popped up. What does that mean?
