oxygen sensor voltage high
Hey guys, i purchased a 2002 chrysler 300m with 70k miles couple weeks ago. The previous owner used to put regular gas and i started putting midgrade. Couple days later, check engine light came on, had it scanned and it said oxygen sensor voltage high, so we did a different test on the scanner, and it showed a wierd reading on bank 1 sensor 1, changed that sensor, filled up the gas tank and drove for about 30 miles, the light came back on. Is bank 1 sensor 1 the passenger side top sensor and any ideas on what might be causing this?
RE: oxygen sensor voltage high
O2 SENSOR RETURN CIRCUIT OPEN
O2 SENSOR SIGNAL SHORTED TO VOLTAGE thats what u are looking for if u say u replaced the sensor already bank 1 sensor 1 would be bank 1 is the closest spark plug to u if u were looking at the engine stright on. a 3.5 would be the passanger side bank 1 and sensor 1 is upstream. or closest to the engine. Here is the chrysler test to fallow I know the format on here will be funkey because this is a cut and past from a pdf file. TEST ACTION APPLICABILITY 1 Start the engine. Allow the engine to reach normal operating temperature. With the DRBIIIt, read the O2 Sensor voltage. Is the voltage above 3.99 volts? All Yes ! Go To 2 No ! Go To 8 2 Turn the ignition off. Disconnect the O2 Sensor harness connector. Ignition on, engine not running. With the DRBIIIt, monitor the O2 Sensor voltage. Is the O2 Sensor voltage below 4.8 volts? All Yes ! Go To 3 No ! Go To 5 3 Turn the ignition off. Disconnect the O2 Sensor harness connector. Ignition on, engine not running. Measure the voltage on the O2 Sensor Return circuit in the O2 Sensor harness connector. Is the voltage at 2.5 volts? All Yes ! Replace the O2 Sensor. Perform POWERTRAIN VERIFICATION TEST VER - 5. No ! Go To 4 4 Turn the ignition off. Disconnect the O2 Sensor harness connector Disconnect the PCM harness connector. CAUTION: DO NOT PROBE THE PCM HARNESS CONNECTORS. PROBING THE PCM HARNESS CONNECTORS WILL DAMAGE THE PCM TERMINALS RESULTING IN POOR TERMINAL TO PIN CONNECTION. INSTALL MILLER SPECIAL TOOL #8815 TO PERFORM DIAGNOSIS. Measure the resistance of the O2 Sensor Return circuit from the O2 Sensor harness connector to the appropriate terminal of special tool #8815. Is the resistance below 5.0 ohms? All Yes ! NOTE: Before continuing, check the PCM harness connector terminals for corrosion, damage, or terminal push out. Repair as necessary. Replace and program the Powertrain Control Module in accorance with the Service Information. Perform POWERTRAIN VERIFICATION TEST VER - 5. No ! Repair the open in the O2 Sensor return circuit. Perform POWERTRAIN VERIFICATION TEST VER - 5. 96 DRIVEABILITY - NGC P0132-O2 SENSOR 1/1 VOLTAGE HIGH — Continued TEST ACTION APPLICABILITY 5 Turn the ignition off. Disconnect the O2 Sensor harness connector WARNING: WHEN THE ENGINE IS OPERATING, DO NOT STAND IN A DIRECT LINE WITH THE FAN. DO NOT PUT YOUR HANDS NEAR THE PULLEYS, BELTS OR FAN. DO NOT WEAR LOOSE CLOTHING. Start the engine and allow the engine to idle. Measure the voltage on the O2 Sensor Signal circuit in the O2 Sensor harness connector. Is the voltage above 5.0 volts? All Yes ! Repair the short to voltage in the O2 Sensor Signal circuit. Perform POWERTRAIN VERIFICATION TEST VER - 5. No ! Go To 6 6 Turn the ignition off. Disconnect the O2 Sensor harness connector Disconnect the PCM harness connector. CAUTION: DO NOT PROBE THE PCM HARNESS CONNECTORS. PROBING THE PCM HARNESS CONNECTORS WILL DAMAGE THE PCM TERMINALS RESULTING IN POOR TERMINAL TO PIN CONNECTION. INSTALL MILLER SPECIAL TOOL #8815 TO PERFORM DIAGNOSIS. Measure the resistance of the O2 Sensor Signal circuit from the O2 Sensor harness connector to the appropriate terminal of special tool #8815. Is the resistance below 5.0 ohms? All Yes ! Go To 7 No ! Repair the open in the O2 Sensor Signal circuit. Perform POWERTRAIN VERIFICATION TEST VER - 5. 7 NOTE: Before continuing, check the PCM harness connector terminals for corrosion, damage, or terminal push out. Repair as necessary. If there are no possible causes remaining, view repair. All Repair Replace and program the Powertrain Control Module in accordance with the Service Information. Perform POWERTRAIN VERIFICATION TEST VER - 5. 8 NOTE: The conditions that set the DTC are not present at this time. The following list may help in identifying the intermittent condition. WARNING: WHEN THE ENGINE IS OPERATING, DO NOT STAND IN A DIRECT LINE WITH THE FAN. DO NOT PUT YOUR HANDS NEAR THE PULLEYS, BELTS OR FAN. DO NOT WEAR LOOSE CLOTHING. With the engine running at normal operating temperature, monitor the DRBIIIt parameters related to the DTC while wiggling the wire harness. Look for parameter values to change and/or a DTC to set. Review the DRBIIIt Freeze Frame information. If possible, try to duplicate the conditions under which the DTC was set. Refer to any Technical Service Bulletins (TSB) that may apply. Visually inspect the related wire harness. Look for any chafed, pierced, pinched, or partially broken wires. Visually inspect the related wire harness connectors. Look for broken, bent, pushed out, or corroded terminals. Were any of the above conditions present? All Yes ! Repair as necessary Perform POWERTRAIN VERIFICATION TEST VER - 5. No ! Test Complete. |
