power windows
My front passenger power window only goes down...any ideas on the potential source of the problem? It is NOT the regulator or motor as I was forced to connect the power supply to thedrivers door in order to get the thing back in the full up position.
RE: power windows
possible driver side master switch
RE: power windows
Thanks for the quick reply...
I just noticed this morning that the rear passenger window will not opperate from the master switch, but it works from the switch on the door itself. Also of note, the front passenger window would go down but not up from both the master switch and the switch on the door itself. Does this seem more/less likely to be a problem with the master switch? I am just a but uneduacted and confused why/how this could happen. Thanks again.... |
RE: power windows
OK..I ended up repleacing the master switch and no change...I am still unable to raise the front passenger window, and the rear right side is still totally inop...
