Transmission issues
My sister's '99 Concorde check engine light came on and she noticed a little difference in shifting. I checked the PCM with anActron scanner an received the following codes:
1st = P0733 2nd = P0715 3rd = P0700 4th = P0700 Does anyone know what might cause this or has had the same codes and know a fix. She has limited funds so if I can fix it for her and foregothe dealer it would be a good thing. The car has been well maintained w/61,000 mi.. Thank you for all suggestions and experiences, Dave |
RE: Transmission issues
P0733-GEAR RATIO ERROR IN 3RD
P0715-INPUT SENSOR ERROR P0700-INTERNAL TRANS CONTROLLER sounds like speed sensors to me replace both input and output 30 bucks each they are outside of teh tranny and screw in. |
Thanks for the advice. I only replaced the input sensor but that seemed to do the trick. Dave
RE: Transmission issues Please HELP fast.
I currently have a 97 Chrysler LHS. The transmission went into limp-n mode and threw codes 56, 57 and 28. I changed both input and output sensors and still get codes 56 57. After installing a new MVLPS I now get a code 24 and 28. The shift lever also moves out of Park w/o pressing the brake pedal.
I double checked all ground points and they are good. What's next? TCM? Any ideas please let me know. |
sorry i dont know what the codes u gave are i need p codes or chrysler codes
