Mallory RCD MSD Lenco TFX Strange Brad Titan PSI SSI
https://s3.racingjunk.com/ui/1/76/50...nge-Brad-T.jpg
2017-11 Inventory List RCD MSD Mac Lenco TFX Strange Brad Titan PSI SSI Its All Here In Stock 2XL Dunn and Gone Racing shirts 5.00 each with any order ENGINE PARTS Enderle pump 200 Waterman pump 750 KB valve covers, single plug 300 Crank hubs with degree rings 125 ea New Burst panels Big Show fuel cams 50 ea BDK slide valves call Hemi push rods 10 ea Hundreds Hemi 4.187 nitro pistons new 40 ea Hundreds Hemi 4.187 nitro pistons used but good 20 ea Hundreds of new oil and second ring sets 10 per hole KB dual plug valve covers, carbon hydro dipped 450 RCD gear drive for Brad or KB 500 BBC ilder bracket and pulley 200 BBC valve covers 50 KB billet wet sump pumps 350 ea 3 KB cast pumps 125 ea P and P Dry Sump Pump 650 KB Brad crank support 450 KB 3.750 crank standard/standard ready to install 2000 Main bearing sets 50 ea Moroso Billet KB/Brad dry sump pan 350 KB/Brad Mega dry sump pan with adapter plate 350 Stage 5 intake rockers 40 ea Kluff style exhaust rockers 75 ea HP6 filter assembly with lines 125 O-Berg filter 125 Blower snouts and drives 250 ea 8 mm, 11mm, 13.9, 14mm blower pulleys 40 ea Tons of nozzles, jets, bodies, poppets SSI fuel blowers 2500-4000 Complete PSI Big Show set back blower with manifold for 100 tall fuel heads 7500 Mooneyham 14-71 standard rotor blower with snout 2250 Lots of spark plugs 2.50 ea Dual Hemi mag drives 350.00 each Nice Hemi blower manifold for standard deck with 100 tall heads 900 Mag clamps 20 ea TFX pans, dragster and funny car 350 ELECTRIC STUFF 1 MSD Top Fuel Tester 1 MSD Delay Timer 1 MSD 44 mag fres... $2,017.11 Posted by: dunnandgone Location: MONTICELLO, IL Post Date: December 5, 2017 Expires: February 27, 2018 More... |
