Audio help needed
I'm not sure where to post this so I posted here and Other models.
I have a 1988 Chrysler 5th Avenue that I want to install a after market stereo, but I have hit a rather small wall. I have the install kit, but when I was searching for the wire harness I found 2 things that kind of confused me a bit. I found this which they are saying is required for my car http://www.discountcarstereo.com/detail.aspx?ID=274 Now here is where the confusion comes in, I have also found this http://www.installer.com/item/displa...php?it=71-1817 So which one do i need? Also does anyone know where I can find a diagram on how to remove the dash? |
RE: Audio help needed
I would definately get the Adapter unit...the first one.
The other one would require you to splice into the existing wiring.......that's a no_no |
^^^^^agreed^^^^^^ You dont want to cut up your factory wiring. whenever possible use adapters that just plugs into stock, its alot easier to hook up, and later on if you remove it alot easier to undo.
